CTM SysAdmin Password
Is there a way to recover a lost CTM SysAdmin password?  The customer is using CTM v9 on a Sun station and Oracle database.
I found a discussion in here, the same problem but in CTM8.
is this (below) solution still valid for the CTM9 and Oracle Database?
Hi Randall,
Use this SQL command sequence
this will reset the pwd to Ctm123!
update User_Table  set UserLoginDisabled = 0 where UserName ='SysAdmin';
update User_Table set LastLoginTime = Null where UserName = 'SysAdmin';
update User_Table set LOCKEDSTATE = 0 where UserName = 'SysAdmin';
update User_Table set AUTODISABLEINTERVAL = 0 where UserName = 'SysAdmin';
update USER_TABLE set USERPASSWORD = 'F6E839178611157BA182FBED1CAEF056' where
USERNAME = 'SysAdmin';
update User_Table set PASSWORDSETTIME='05/03/2008' where UserName='SysAdmin';
commit;
Hope this helps.
-Joe
Thanks in advance!
Ignatius S
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: CTM SysAdmin Password
Yes.  It will work for 9.0.
thanks for the reply....
387
