CTM
Dears;
When i tries to connect from CTM client to the CTM server the i receive the following error.
(see the attached)
Re: CTM
from the CTM FAQ:
Q. I cannot log in to CTM. I just installed Solaris, Oracle, and CTM, but when I launch the client and enter the username, I get the "EID-100: Fatal error: Cannot connect to EMS server. Check configuration and retry." error message. What should I do?
A. There are a variety of causes that can trigger this error message. Use these suggestions to correct this problem:
* Verify that you can ping the CTM server IP address from the CTM client.
* Verify that all of the server processes are running (Oracle, tnslistener, and CTMServer).
* Start the server in debug mode. As the root user, issue this command from a terminal console window on the CTM server: /opt/CiscoTransportManagerServer/bin/CTMServer -d . This command dumps information into the terminal console window and indicates the cause of the problem.
I hope this helps.
Re: CTM
by the way, you can find the FAQ here:
http://www.cisco.com/warp/public/127/ctm_faq.html#qa8
Re: CTM
Hi, i don't understand the debug output:
whats wrong?
Re: CTM
Thanks Sir;
This problem had been resolved.
it's more than one year.
Thanks.
336
