Community Member
CWDM and OC-3
Did anybody try to use CWDM-MUX-4 for 1310 nm links like
OC3 ?
We have BPX with BXM-155-4 cards and want to build something like
BPX---OC3----CWDM---------------------------------CWDM----OC3----BPX
then CWDM GBICs will be used to add Gigabit Ethernet links on top of it .
Vladimir.
Silver
Re: CWDM and OC-3
I have worked with BPX---CWDM--CWDM---BPX. Haven't tried CWDM with OC3. However, the GBICs in the list does not show one to work with 1310 nm. Check it.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/mod_inst/02prepar.htm#1032575
You could also refer to the data sheet available at:
http://www.cisco.com/warp/public/cc/so/neso/olso/nesocdwm/cgbic_ov.htm
Community Member
Re: CWDM and OC-3
Cisco says that CWDM-MUX-4 does not pass 1310 nm wave between
"pass" and "network" ports.
Vladimir.
265
