Community Member
dB loss in Avaya SMF Cabling
We have completed the Large MAN Cabling project at one of the oldest University in India. Following components are used:
1. Avaya SMF 9micro Cables.
2. Avaya SMF LC Connectors.
3. Avaya LC Coupler.
and other Avaya Fiber structured cabling products.
According to Avaya site we have taken following Equation for Acceptance test of this cabling.
Link Attenuation = Cable Attn + Connector Attn + Splice Attn WHERE
Cable Attn (dB) = Attn Coefficient (dB/km) * Length (Km)
Connecter Attn (dB, for LC) = (number of connector pairs * 0.14) + 0.24
Attn Coefficient (dB/km) = 0.4 at 1310 nm and 0.3 at 1550 nm
We are facing following problem:
1. Large variation in dB loss readings for different cores. (Reading varies by 1 to 1.5 dB every time u measure)
2. 40% readings are overshooting the expected reading (As per above formula)
Help Required:
1. Confirmation that weather these formulees are valid?
2. Sample Readings for SMF LC connectorization.
3. General allowed variation in the LC / SMF reading.
Help will be greatly appreciated.
regards....Prakash Somani
Re: dB loss in Avaya SMF Cabling
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Community Member
Link Loss formula should be :
Cable Loss + Connecotor Loss + Splice Loss + Coupler LOss
Note 1. IF the Connecotrs were spliced on a loss of 0.30dB is typical
Note 2. Splice loss should be calculated at 0.10 dB per splice
Note 3. Coupler loss is approx 3.5 dB for a 50/50 split
Make sure the test equipment is referenced correctly and do not change the test jumpers.
The test set up should be
TX----------------cc-------------------RX c=connector
zero this out and begin testing
hope this helps
Community Member
I would only add one point.
Give the optical source time to settle down.
If the environment is optimal, it will still take two or three minutes for the source to warm up and stabilize. In a bad environment, it could take seven minutes for the source to emit a consistent signal.
Good luck!
