08-11-2008 06:06 AM
Dear All,
I. ONS 15454 DWDM: 1. AD-2C Module - 1546 TX,RX - 1546 TX,RX - EXP TX,RX - COM TX,RX2. OSCM Module - TX,RX.3. OPT-PRE - MON TX,RX - COM TX,RX - DC TX,RX .4. OPT-BST - MON TX,RX - COM TX,RX - OSC TX,RX - LINE TX,RX.5. TCC2P Active and Standby.6. 10 DME Module. II. ONS 15454 DWDM: 1. AD-2C Module - 1546 TX,RX - 1546 TX,RX - EXP TX,RX - COM TX,RX2. OPT-PRE - MON TX,RX - COM TX,RX - DC TX,RX .3. TCC2P Module - Active and Standby.4. 10 DME Module.
I would like to know that is it the right combination.
Client is looking for point to point connectivity for servers location at different location.
08-11-2008 06:17 AM
Impossible to tell you this. You did not give enough specifics such as what the connectivity is for (i.e. G or FC etc), and especially the distance from site to site or more specifically the fiber characterization/loss. If you ran this in MetroPlanner, then you should be fine. If not, without the fiber loss info, the amp cards could be overkill. The other cards should be fine.
08-11-2008 06:29 AM
Dear,
We are implementing this setup for DISASTER RECOVERY. Basically we are looking for point to point link using ONS 15454 at both location.I joined this company very recently and I am very new to SDH.
I would like to know which all module's are required to build up a point to point link between two location.
Waiting for your reply.
08-11-2008 12:57 PM
You need to verify the network using Cisco's Transport Planner (formerly Metro Planner). Work with a Cisco SE or optical reseller. They will need to understand your fiber network to confirm necessary circuit packs.
