11-29-2011 11:36 PM
I am having a fiber for internet converted to ethernet using ISP's media convertor . Now that media convertor is not that good and hangs sometimes . Edge equipment is ASA and if I need to put fiber there I would require to puchase SSM-4GE which is quite expensive at the moment for us . I was thinking if I can put the Fiber into Layer 2 switch and take out an ethernet cable from switch to firewall . Put both those ports into VLAN xxx and put ip address to the firewall .
This solution should work and in this case the L2 switch would become media convertor ( 2960S ) . If this is correct can I use this kind of setup on mass scale ?
Comments please
11-30-2011 05:56 AM
Why not have the ISP replace the faulty media converter? The ISP may require the media converter as their demarcation point (hand-off) for their service to your company.
11-30-2011 06:17 AM
I will need to talk to ISP to check out if they are using the media convertor for any other purpose . But if ISP says that you can pick up that fiber directly and put into ASA/Switch/RTR then I can try that solution right ?
12-02-2011 06:24 PM
Yes you can do that just fine for the purpose you ask.
As far as scale, 2960S (non-compact) models have either 2 or 4 SFP ports so you could do thise for up to four such connections with the right 2960S model.
Hoep this helps.
