Silver
GBIC - 1 Lamda - Ring - Is it fault tolerant?
I am using GBICs in 3550s. Two in each switch. GBICs feed the OADMs. All switches/OADMs are in a ring topology (real ring, not collapsed). Is it right to say that the solution is fault-tolerant. One two nodes going down doesn't take any other node down. Correct?
Thanks.
1 REPLY
Bronze
Re: GBIC - 1 Lamda - Ring - Is it fault tolerant?
"Fault tolerant" can mean a lot of things. But it sounds like no single node, component, or cable failure should cause an outage in your case. So your architecture would generally be considered fault tolerant.
165
