06-22-2008 06:48 AM
Can I connect a GBIC port to a SFP port ?are there suitable fiber cords for the same?
06-22-2008 07:21 AM
Yes, you can connect a GBIC port to an SFP port as long as they are the same type (singlemode or multimode) and the signal levels meet the SFP/GBIC specifications.
The following is one example of a fiber optic patch cord to transition from SC connector (GBIC) to LC connector (SFP). There are thousands of suppliers of patch cords.
http://www.panduit.com/groups/MPM-OP/documents/PartDrawing/110144.pdf
10-30-2008 11:15 PM
There are also some GBICs/SFPs that are designed to work on different frequencies than the standards.
CWDM does this and occasionally I find that people end up with one of one type, and the other side is another type.
Just take a look at their names and you can usually figure out what they are.
This page seems to be a good quick list of common GBICs and SFPs.
