GLC-LH-SM transceiver modules
I have an application where two C2960-24TC-L switches located 450m apart have to be connected via a 62.5 MM fibre link using the GLC-LH-SM transceiver modules. The fibre link is terminated to SC patch panels at both ends. The question is can off the shelf 62.5 MM LC-SC patch cords be used to connect the switches to the patch panels? If not please recommend a suitable patch cord, thank you.
Everyone's tags (3)
Hall of Fame Super Gold
Re: GLC-LH-SM transceiver modules
Should be fine.
It is recommended that you use  Mode Conditioning Patch Cabes for your application; model CAB-GELX-625= (or similar from another vendor).
The following documents outlines the implementation of these cables.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/product_bulletin_c25-530836.html
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/OL_19329.html
I hope this helps!
Thanks for the advice
3110
