Community Member
high latency on a p2p circuit between two CE-1000-4 cards
i'm doing some tests in a lab environment; I have two ons15454 with CE-1000-4, STM64-LH 1558.17, tccp2, xc-vxc-10g.
I created one rss-dcc between the two NE, everything is up.
I created one p2p vc4-4c circuit beteween the two CE cards and it seems ok, then i connected two switches, one to the first ons and the other to the second ons and started pinging.
The responses time are too high, average is 2 second and maximum is 10 second.
I checked and changed every piece of hardware, staring from the fibers and ending to the cards (the only one thing i did not change is the etsi chassis)and
nothing changed.
In the same NEs i have ML-1000-2 cards, i created another vc4-4c, configured rpr and then started pinging: the results are good (average time is 1 ms).
What did i do wrong with the CE cards?
May anyone help me?
Thanks in advance,
Stefano B.
Bronze
Re: high latency on a p2p circuit between two CE-1000-4 cards
Community Member
I have a similar problem. my ping has a big delay every 9 or 10th one. I don't know how your reference URL will help. The CE 1000-4 is running on the Cisco 15454 Sonet ADM.
Community Member
Stefano,
did you resolve your high response time on pings with the CE-1000-4 cards? I have similar problem with my CE-1000-4 cards except that my pings will go thru normall 9 out of 10 times. The tenth one will take over 1 sec to complete.
263
