Community Member
How many ‚„‚a‚is it?
Hi.
wavelength:1310 nm
9 microns and single mode
distance :10Km
How many ‚„‚a‚ is attenuate of optical? (reference value)
Re: How many ‚„‚a‚is it?
Well, this is difficult to answer as it will depend on the fiber used and its own dispersion and attenuation properties.
Gold
Typical SMF cable attenuation at 1310nm wavelength is 0.3 to 0.5dB/km. The actual value should be obtained from the cable manufacturer. I use 0.4dB/km for calculating expected loss over the spans we build.
For a hypothetical 10km run, total attenuation expected would be:
cable attenuation of 4.0dB (10km * 0.4dB/km); plus
connector pair loss of 3.0dB (1.0dB per pair, or 0.5dB per connector); plus
splice loss of 0.4dB (0.1dB per fusion splice);
equals 7.4dB.
This is within the 1000BASE-LX/LH GBIC's power budget of 9.5dB.
This fiber span consists of a 2-meter patch cable at each end (with each patch cable having a pair of connectors); and 9.996km of SMF with four fusion splices along its length (and a connector at each end, located in a fiber patch panel).
Cisco has a page which is helpful in illustrating the concept:
Calculating the Maximum Attenuation for Optical Fiber Links
http://www.cisco.com/warp/public/127/max_att_27042.html
And Corning has a neat on-line Link Loss Budget Worksheet:
http://www.corningcablesystems.com/web/privnet/webapp.nsf/linkloss?OpenForm&Seq=9
This is probably a little late to help the original poster; but hopefully it will help somebody.
325
