How to adjust voltage alarm threshold on ONS 15310 CL
Hi all,
Does anybody know how to adjust voltage alarm threshold on ONS 15310 CL, cause it's not available on CTC. And just asking if the function would be available by TL1/Corba?
Ricky
Silver
Re: How to adjust voltage alarm threshold on ONS 15310 CL
It's not working. Actually, I've tried TL1 command "SET-ALMTH-EQPT:::1::BATV-HIGH,-54.5;" on ONS15310, then following with "Invalid Command". Moreover, it's not an available argument to "-ALMTH" following the "SET" command for ONS15310. Thanks anyway.
Ricky
Hi All,
Here's response from CISCO TAC fyr:
After checking this issue further with developers, here is outcome :
* The threshold is not programmable.
* It is preset in hardware.
* There is no way to change it presently.
So, as it is preset in the hardware, according to DEs, there is no way at
this stage to make it user configurable - no workaround is available.
Just wandering if customers want the programmable threshold can be a feature request!!
269
