Webcast-Catalyst9k
How to convert 1310 nm to 1550 nm
We need to connect a 1310 POS interface to a device with 1550 interface.
Is there converter for this type of setup? or any advise?
Thanks!
Re: How to convert 1310 nm to 1550 nm
Allied Telesyn media converters make it possible to mix media and speed on a network to optimize price/performance goals, whether you are extending legacy networks with the latest technology, or connecting inexpensive, lower bandwidth desktops to a state-of-the-art fiber optic backbone.
Theoretically , the wavelengths (1310,1550) correspond to the transmit and the recievers are wideband . You don't need a converter at the Rx end , since the Rx can detect light over a relatively wide range of wavelengths..
http://www.cisco.com/en/US/products/hw/optical/ps2006/products_installation_and_configuration_guide_chapter09186a008007f6eb.html
To be on the safe side , it would be prudent to measure the power levels of the incoming signal and make sure that it's within the acceptable levels for the Rx . The wavelengths should not be a cause for much concern.
Hope this helps ,
-P
578
