How to use CTC debug command?
As be known that hold ctrl+shift while clicks "help -> about CTC" above the CTC window resulting the debug window occurs.
Does anyone know the debug command usage?
Since we got a provisioning issue on the 15454-CE card which exists a "hidden" crossconnect on a port, and not shown on CTC.
Any advice will be appreciated!
Ricky
1 REPLY
Re: How to use CTC debug command?
The best way to look for cross connects is via TL1. Open the TL1 window and log in:
act-user:::$::;
rtrv-crs:::$;
The hard part is getting the AID correct. For example, the old style OC48 cards would be "STS-6-1-all". You will have to spend some time in the TL1 manual to get the correct AID.
Hope this helps,
Tim
290
