Community Member
Info. request on Prisma 2 forward optical Tx & Rx
I’m looking into possibilities of using Prisma 2 Forward Optical Receivers and 1550nm Transmitters.
I have looked at datasheets available on the website.  It was clear and quite informative.
However, could any of you provide more optical specifications on these products?
Particularly, I’d like to ask a couple of questions.
1)      Prisma 2 1550nm Transmitters for FTTP :
                Max.output power of the optical signal
                Detailed spec. on the SBS threshold
2)      Prisma Forward Optical receivers:
Rx. Dispersion tolerance
Min. required carrier to noise ratio (CNR) or OSNR
Thank you
Han
301
