12-18-2013 08:16 AM
Hi, anyone knows why the interface remains up, when is receiving a lower power than the expected. Can we avoid this ?? how ?
SPA-1X10GE-L-V2 with XFP-10GLR-OC192SR
The Receiver sensitivity (maximum) is 10GLR SR-1: -12.6 dBm
We were receiving -20 but, the interface remain up.
Solved! Go to Solution.
01-14-2014 07:18 AM
i think its normal, many times observed in lab during re-ceates, photodiode stops sensing beyond its recevier senstivity but the light is enough to show the port UP and also no issues with frames/traffic.
but you may observe errors after sometime.
example:
many ONS-XFPs (full tunable) recevier senstivity is around -26dBm, but they remain UP with low optical power close to -29, -30, few times power shown -40 (means no optical power) by system.
so its normal.
01-14-2014 07:18 AM
example:
so its normal.
01-14-2014 12:21 PM
Hi ! thanks very mych for your response.Do you think we can tune this, to avoid this situation ??
01-15-2014 05:57 AM
no its not possible to tune it.
but yes we can set some threshold so that will get alarms when it goes below certain level.
this we can do on ONS equipments, need to check for routers and switches.
