Is SFP-10G-LR compatible with XFP-10GLR-OC192SR
will it work with one on each side of the fiber?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You just posted spec for the
You just posted spec for the SR modules while your original post was on the LR modules. (Since fixed)
The SFP-10G-LR is a 1310 nm singlemode transceiver rated for up to 10 km spans.
The datasheet notes that these module types have  "Optical interoperability with 10GBASE XENPAK, 10GBASE X2, and 10GBASE XFP interfaces on the same link".
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
The XFP module data sheet indicates that iit is a mutirate transceiver supporting both 10GBASE-LR Ethernet and OC-192/STM-64 short-reach (SR-1) Packet-over-SONET/SDH (POS) applications.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/10-gigabit-modules/product_data_sheet0900aecd802a61b9.html
As such, it is compatible with the SFP-10G-LR as long as you have the interface at the equipment configured as a 10 Gbps Ethernet LAN interface (and not a Packet-over-SONET interface or encapsulated Ethernet WAN interface).
Hi Priyank,
Hi Priyank,
I think these two should be compatible. As much as I remember, I have used SFP-10G-LR with XFP-10GLR (don't remember if it was exactly XFP-10GLR-OC192SR) and they worked for me.
I would suggest you should check the optical and electrical characteristics for these two SFP and XFP and if they fall within the same ranges, they should work for you.
Kind regards,
Ghulam
Hi Priyank,
Hi Priyank,
I don't think they are compatible. You would need an SFP-10G-LR on both sides.
Hi Priyank,
Hi Priyank,
Hello Ghulam,
Hello Ghulam,
Thank you for your response. What exactly needs to fall in the same range ? Below are the details for each of the transceivers. Both have the same numbers on comparing
Updated Table to reflect the correct part numbers
Cisco SFP+
Wavelength (nm)
Cable Type
Core Size (Microns)
Modal Bandwidth (MHz*km)***
Cable Distance*
Cisco SFP-10G-LR-Sa
Cisco SFP-10G-LR
Cisco SFP-10G-LR-X
1310
SMF
G.652
10km
Wavelength (nm)
Cable Type
Core Size (micron)
Cable Distance*
Cisco Multirate 10GBASE-LR/-LW and OC-192/STM-64 SR-1 XFP Module for SMF
1310
SMF
G.652
●  10 km (10 Gigabit Ethernet)
●  2 km (OC-192/STM-64 SR-1)
Power
Product
Type
Transmit Power (dBm)*
Receive Power (dBm)*
Transmit and Receive Wavelength (nm)
Maximum
Minimum
Maximum
Minimum
Cisco SFP-10G-LR-S
Cisco SFP-10G-LR
10GBASE-LR 1310nm SMF
0.5
-8.2
0.5
-14.4
1260 to 1355
Product
Power Consumption (W)
Operating Temperature Range
Cisco SFP-10G-LR
COM
Product
Type
Receive Power (dBm)
Transmit Wavelength (nm)
Maximum
Minimum
Maximum
Minimum
Range
Range
10GBASE-LR/-LW 1310-nm SMF
+0.5
-8.2
+0.5
-14.4
1260 to 1355
1260 to 1565
Product
Cisco XFP-10GLR-OC192SR
1.5
COM
Hi Priyank,
Hi Priyank,
As Marvin mentioned, the spec you provided is for SR modules while your original post was on LR modules. I like the details he provided, so I think the subject optics are compatible.
10GBase-SR SFP supports short link lengths and is the original Multimode optics specification however 10GBase-LR supports long link length of 10km on standard Single-Mode-Fibre (SMF).
If possible you could test SFP-10G-LR and XFP-10GLR-OC192SR using a short fibre to ensure they are working or if you want to put an order I guess you are safe to do so.
You can also check the following link which provides SFP compatibility information.
https://www.compatiblesfp.com/cisco/cisco-xfp/xfp-10glr-oc192sr
Ghulam
Thank you Ghulam for you
Thank you Ghulam for you replies!
You are welcome.
You are welcome.
Thanks Marvin for your
Thanks Marvin for your response!  and thanks for catching the error. I have updated my comment so future readers  do not get confused.
You're welcome. Thanks for
You're welcome. Thanks for rating.
584
