Community Member
Juniper SSG 20 optical interface connection to Cisco 4506
Let me post the same issue to the Optical forum too:
Here's the problem.
There's one Juniper SSG 20 firewall with JX-SFP-1GE-SX multimode fiber interface (850nm) (which I can control) and I have to connect it to Cisco 4506 switch which has WS-X4306-GB module and WS-G5484 GBIC interface (also multimode fiber).
SSG 20 shows link up. Cisco shows link down.
Unfortunatelly I don't have Cisco 4506 to play with, but I have to find solution for this system. Cisco 4506 show version is:
#show version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(25)EWA9, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 21-Mar-07 12:20 by tinhuang Image text-base: 0x10000000, data-base: 0x115C6158
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 34
XXXXXXX uptime is 3 weeks, 1 day, 3 hours, 20 minutes System returned to ROM by reload System restarted at 13:19:45 CEST Mon May 19 2008 System image file is "bootflash:cat4000-i9k91s-mz.122-25.EWA9.bin"
I was able to replicate issue with Cisco 3524 swtich (SSG20 shows link up, Cisco link down, physical down), and solution that I found was to enter interface level command: (config-if)#no negotiation auto. After this command, everything was showing state as "UP" and working as expected (there was traffic going through the optic)
When I suggested this command as a solution, administrator from the other side was claiming that this command returns "invalid input detected at ^ marker".
Can anyone tell me is there any known issue between those two products, and maybe alternative to this command, so I can turn off this IEEE 802.3z negotiation if that's the problem.
Thanks for assistance
Cheers
M.
Community Member
Re: Juniper SSG 20 optical interface connection to Cisco 4506
So I found my solution, but I want to know why is like this.
The solution was to enter on Cisco the following command:
(config-if)#speed nonegotiate
From this link: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/sw_int.html
I can see on section: Configuring Link Negotiation on Gigabit Ethernet Ports that this command is doing negotiation exchange of flow-control parameters, remote fault information, and duplex information. Link negotiation is enabled by default.
And the funniest thing of all is, this speed nonegotiate command doesn't deal with the speed at all :)
Can someone confirm me what are remote fault information and flow control parameters
You may want to also post this question on LAN or WAN Routing & Switching forums.
Community Member
Thanks for the suggestion, I already did this :)
I'm sorry for posting on two forums at the same time, but it's a bad issue for me and I suppose it's important to be solved, not only for me, but to whole community out there who uses Juniper, Nortel or other devices with optical multimode fiber.
Thanks for understanding
M.
693
