Keep loosing connectivity to ONS15454-E
Hi there...
My computer keeps loosing the connection to the nodes in CTC, both the local node and the remote node.
I'm using JRE version 1.6.0_07 and CTC is version 8.5.1.
Anyone who has any ideas?
Silver
Re: Keep loosing connectivity to ONS15454-E
Might be communication interuption between the card and client. Reboot the device and try again it will resolve.
I had same problem ... in my case I used the following solution:
It's a network problem.
You have a firewall into your network.
You need to go from CTC on network parameters (provisioning --> network) and setup:
Enable SOKCS proxy
SOCKS proxy only.
This should work, but take care about your network topology.
E.G.: if you have some other host NOT 15454 connected to your network it's possible that you lost them.
So try it ... maybe, it will solve your problem ... Regards Radim
170
