LC-FE-100LX
I'm trying to connect 2 Catalyst 2960S over multimode 62,5my fiber cable.
I use LC-FE-100LX spf's but theone end is always operating in half duplex mode.
My final goal is an etherchannel running 2x100mbit in full duplex mode.
I have an etherchannel configured but for the moment i'm only using one link (Gi1/0/25)
when i specify duplex full on both interfaces one interface operate in half duplex(but still link up) and connectivity.
switch 1
interface Port-channel1
     switchport mode trunk
     switchport nonegotiate
     spanning-tree portfast trunk
interface Gi1/0/25
     duplex full
     channel-group 1 mode on
sh interface status
     Gi1/0/25 Connected trunk 1 half a-100 100baseLX-FE SFP
switch 2
interface Port-channel2
interface Gi1/0/25
     duplex full
     channel-group 2 mode on
sh interface status
     Gi1/0/25 Connected trunk 1 full a-100 100baseLX-FE SFP
Why is one end operating in half-duplex mode????
Can't find any specs for GLC-100-LX over multimode fiber.
I assume that specs are the same as 1G LX spf's over multimode with a mode conditioning patch core
LC-FE-100LX
The data sheet for the 100Base-LX SFP does not indicate support for MMF; only SMF.
Hall of Fame Super Silver
LC-FE-100LX
Like Tom says, the GLC-FE-100LX SFP is singlemode fiber only. You'll be shining a laser (coherent signal) down a medium (MMF) not designed for optimum propagation of that type of signal. Any signal you recover at the other end will be the luck of the draw as opposed to by design.
The mode conditioning patch cable can mitigate this for a small subset of transceivers and give you a working setup but unfortunately that does not include the one you are using. (Reference) You didn't mention; but is your MMF link OM1, 2 or 3 rated?
LC-FE-100LX
Thanks a lot for your answers.
Btw. Its's an old OM1 (62,5) fiber. Nobody knows the length, but close to 2Km.
Il'l give a pair of GLC-FE-100FX at both ends a try.
Regards.
788
