Maximum Bandwidth on ML-1000-2 POS Interface
I have an ML-1000-2 card on Cisco 15454 ONS, I want to set up IP between two ONS with STM-4 SDH between them. I wand to map the STM-4 to the POS interface on the ML-1000-2 card. Will this POS take the STM-4? If yes, what is the maximum STM bandwidth I can map to the POS interface on the ML-1000-2?
1 REPLY
Silver
Re: Maximum Bandwidth on ML-1000-2 POS Interface
I wand to map the STM-4 to the POS interface on the ML-1000-2 card. Will this POS take the STM-4.
Yes you can map STM-4. But u can use only if u have XC-10G cross-connect card
You can map both port to a STM 16 rate. Each port to STM 8bandwidth.
info from cisco
The new Cisco IOS-based ML-1000-2 card is used for Gigabit Ethernet (1000
Mb/s) when the XC-10G cross-connect card is in use. It supports Layer 2 and
Layer 3 services and provides up to 2.4 Gbps of transport bandwidth, software
provisionable in transport bandwidths from 50Mbps to the ports full line rate, in
STS1, STS3c, STS6c, STS9c, STS12c and STS24c.
452
