Community Member
MetroPlanner 7.0.6 Upgrade
I am a new to MetroPlanner.
I would like to convert ROADM traffic to present traffic and make sure the successful analysis using upgrade function. I would like to know how to force certain installation parameters.
1 REPLY
Bronze
Re: MetroPlanner 7.0.6 Upgrade
ROADM is part of the equation but you need or to place future services if you have a rough idea of what could be or (and MP included this feature just to guarantee that any possible traffic will be supported without changing MP file or BoM in the network) using Any-To-Any traffic. When you design a ROADM network and you want to be able to reroute the traffic around the
network without knowing what the traffic will be in the future, you need to set up any-to-any services. This feature will guarantee you that MP file loaded in the network and future services (if of course optical results are green) are supported with no change.
The folowing URL will help you :
http://www.cisco.com/en/US/docs/optical/metroplanner/metroplanner_7_01/operations/guide/mp70102.html#wp1193153
200
