MGBLH1 SFP
Hello
mgblh1 gbic support multi-mode and single mode fiber optical.
  • 62.5/125um MMF @ 200MHz/km, up to 500m
  • 50/125um MMF @ 500MHz/km, up to 2,000m
  • 9/125um SMF, up to 40km
  • my question is what happen if i use this gbic with single mode wire under 500m between my sge2000p switch.
    thanks
    1 REPLY
    Silver
    Re: MGBLH1 SFP
    If you already purchased MGBLH1 SFP 9/125um SMF, up to 40km then
    1.Either check optical power and if it is less than -3dBm then use it (Like -4dBm)
    2. If it is more than -3dBm (-2, -1 etc )then use an 5dBm optical attenuator
    3.If not bought can go for single mode 10Km or 2 Km multimode (MGBLX1 1000BASE-LX SFP transceiver, for single-mode fiber, 1310 nm wavelength, support up to 10 km, MFEFX1 100BASE-FX SFP transceiver, for multimode fiber, 1310 nm wavelength, support up to 2 km)
    Depending on your current and future requirement
    618
