Missing Distance Extension Tab
ONS15454 Multishelf running REL 7.22. There are two MXP_MR_10DME cards in shelf one and two MXP_MR_10DME cards in shelf two. On the MXP_MR_10DME cards in shelf one there is a Distance Extension Tab when you select Provisioning in Card View but on the MXP_MR_10DME cards in shelf two the Distance Extension Tab is missing. Exactly the same on another node, Distance Extension present on shelf one but missing on shelf two. As far as I can tell all the cards have the same HW Part # etc.
198
