Webcast-Catalyst9k
Monitoring incoming traffic on CTC
Is there a facility on CTC which could be used to monitor incoming traffic i.e.howcan we see a loop (soft or hard) applied externally. To my knowledge, I don't believe that SDH has this level of intelligence since it only recognises 1s and 0s rather than, say MAC address.
Thanks in advance
Hall of Fame Super Silver
Re: Monitoring incoming traffic on CTC
Not generically. For POS interfaces there is the J1 path trace (http://www.cisco.com/warp/public/127/POS/path_trace_byte.html). Generally speaking though, you need to use an external test set.
Thanks again for the response. What I wanted to know was if a link is up and working ok, then obviously the ports at either end are Green- Port In Service - No Alarms.
If I asked a 3rd party tail provider to loop back either their router or PABX how would I see the loop, i.e. would my port on the A-End device change colour and if so what colour would it change to.
I cannot believe that CTC doesn't have this functionality, otherwise no person would ever buy Cisco SDH
Sorry but I'm pretty sure CTC doesn't do this - nor does CTM. The Cisco SONET/SDH products transport and multiplex signals. They don't perform test set functionality.
244
