multi-wire optical cable for 150...200 meter connection
Andrey128
Please suggest multi-wire cable to connect switches located ~150...200 meters away from each other.
It is needed to have at least 8...10 wires inside such type of optical cable.
Marvin Rhoads
Cisco doesn't sell optical cabling. Typically people have optical cable installed by a cabling vendor from rack to rack and terminated in patch panels.
The recommended specification these days for most intra-building applications is OM 3 or ideally OM4 50 micron multimode cable. You tell the vendor how many pairs you require and they take care of it for you.
You only then need to procure the 1-2m fiber optic jumpers between the patch panel and the SFPs in your equipment. Again these would be OM3 or 4 50 micron multimode and generally you need LC terminations on both ends. They are commodity items and available from any number of online retailers.
