why we ping the same ip address(210.14.211.242),using different platform,ie cisco router and pc in the same place, but get two different result, one is unreachable,one is reachable.
The Cisco router will use the closest interface to the host you are pinging. If the pc is trying to ping a device across the router, maybe its gateway is set wrong. Maybe theres an access-list in the path. I hope this help a little.
Learn, share, save
