Community Member
need the help
why we ping the same ip address(210.14.211.242),using different platform,ie cisco router and pc in the same place, but get two different result, one is unreachable,one is reachable.
1 REPLY
Community Member
Re: need the help
The Cisco router will use the closest interface to the host you are pinging. If the pc is trying to ping a device across the router, maybe its gateway is set wrong. Maybe there’s an access-list in the path. I hope this help a little.
210
