08-13-2002 06:33 AM
Does anyone know what software is running on the DEMI? I linked up a 16 channel system, connecting the NEMI and DEMI via the bus cable as intructed in the documentation. Telneting into the primary chassis (the one with the NEMI) I can see the other chassis channels 9-16, so my bus cable works. But do I need to care about the software versions between the NEMI and DEMI? Do they have to match?
thanks.
- Ted
08-20-2002 02:01 PM
I see no reference in the docs that they are supposed to match. In fact, I see no updates available in software center. If you're experiencing som eproblem, I'd run it thru the tac support channels
08-22-2002 01:12 PM
Yes, I do not see either. I did speak with tac, they said the DEMI does'nt really have an OS, just a firmware based status reporting program. I'm not experiencing any problems so I'm going to leave it as is.
thanks for the input.
- Ted
