NM-1A-OC3MM & 3640
meerz
I have a 3640 router installed with NM-1A-OC3MM. I upgraded the IOS and the new one is (C3640-I-M), Version 12.3(19), RELEASE SOFTWARE (fc2).
ATM interface is showing in IOS. Do I need a right IOS. If yes than which one.
meerz
Correction for above email
ATM interface is not showing in IOS.
You need an "IP PLUS" image for this mod. Looks like you're running IP-only.
Andrew.
In addition to Andrew's comments you can always refer the below link to find out the ios code with the features you require to have in your box..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
CSCO10892433
Level 4
Level 4
Here is another page regarding this Network Module:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b88.html
There is a table(Taqble 1) listing the ios version and feature set required.
SSLIN
