Community Member
ONS 15252 - Network Managment
Can the network managment show what interface type the client is transmiting? Can the software confirm if the client is transmiting ESCON or STM-1?
Community Member
Re: ONS 15252 - Network Managment
Hi Vinicius,
Client signal should be defined manually before carrying traffic. It is common technology in the field of Optical product. ONLY optical characteristic can be shown automatically....
Cisco ONS15252 can be managed by CTM(Cisco Transport Manger) or CLI(Command Line Interface). You can see the type of client signals(CLIP) through CTM. In addition, you can access the system by Telnet and control the system...
TKS,
Community Member
Hi pobistar,
What will it happen if I define manually a carring traffic and insert other type of traffic? Will it work?
TKS,
257
