Community Member
ONS 15305 with MGX 8800
I want to configure a Lab setup with Three ONS 15305 connected in SDH ring. Two MGX 8800 connected to ONS as provided in the diagram. ONS are connected via STM-1 and I want to connect the MGX with ONS via E1.
I wanted to know if this is a feasible solution.
I wanted to now the min configuration needed to have a talk between all of them. both the MGX confs and ONs confs.
Silver
Re: ONS 15305 with MGX 8800
Yes the solution is feasible.
You have to create E1 crcuit in ONS from A to B.
Configure E1 card in MGX.
ONS dont have config like switch/router.
Check the link for ONS config guide
http://www.cisco.com/en/US/products/hw/optical/ps2001/products_configuration_guide_chapter09186a00808bdd85.html#wp1040823
You can check following links to see the config for MGX
http://www.cisco.com/en/US/products/hw/switches/ps1938/tsd_products_support_configure.html
Community Member
can i connect mgx and router / ONS and router via E1 with ATM encap.
how to go about it. an example or lik to example will be great.
Silver
SDH box (i.e E1 )is not concerned what protocol is going over it. if your both end routers have proper configs think should with ATM encap.
Community Member
what i meant was if some help regarding the configs for MGX / ONS could be found it would be a great help.
212
