ONS 15454 and AC/DC Converter for 220V
I am looking for a AC/DC converter for a ONS15454 for a 220V input.
The ONS 15454 datasheet indicate input current 22A maximum.
The Cisco AC/DC Power Solution datasheet indicate for ONS 15454 a medium solution.
And the same datasheet indicate the small solution is up to 32A for 220V.
Then, can I use the small configuration for ONS at 220V?
Anyone know that? Can you help me with that?
Graciela
Re: ONS 15454 and AC/DC Converter for 220V
What is the hardware configuration of your 15454 including chassis, fan and by slot?
Using the hardware config, you can calcualte the expected amperage.
http://www.cisco.com/en/US/partner/products/hw/optical/ps2006/products_tech_note09186a0080094ae4.shtml
The general power requirement of 22A provides for any possible configuration. Actual configurations may be less. I have some 454s using as little as 9A in the lab.
Thanks a lot for your answer.
I am using a ONS15454 ANSI with only 3 cards installed.
Probably I will install more cards in the future, and I don?t like to change the AC/DC coneverter later.
But, I 22A provides any possible configuration and AC/DC converter provide 32A at 220V.
Why the datasheet are indicating that I need a medium configuration?
Is the datasheet indicating the configuration for 110V or I am missing something?
Thanks a lot. Graciela.
Could I use
The reason the medium size Cisco AC/DC system is recommended for the Cisco15454 is due to the fusing. The medium system has 30amp breakers via the expansion panel (included with a medium config). A small AC/DC system will only have GMT fuses, which, if memory serves me correctly, are only available up to 15amps. So, to future proof your installation, a medium should be the answer.
486
