ONS 15454 MRC 2.5G4
Hi All,
We are trying to install the optical multirate card (MRC 2.5Gig) on ONS 15454 and found the card comming up on standby state instead of active. The version running on the sonet box is 8.5.0 ...The MRC card port 1 is installed with the OC3 SFP's but cable not attached.
Any help would be appreciated .
Anantha Subramanian Natarajan
1 ACCEPTED SOLUTION
Bronze
Re: ONS 15454 MRC 2.5G4
Hi, this is normal. Just go on and enable a SFP, called pluggable port module (PPM). After the first SFP is enabled, the state of the MRC card will change to working.
Cheers
Rene
Bronze
Cheers
Rene
Hi Rene,
Thank you very much ...We were able to do that .
212
