ONS 15454 MSPP Recommendation
jbnair
Currently Being Moderated
ONS 15454 Recommendations
Hello Guys,
Just looking for some recommendations / best practices from experienced ONS 15454 engineers for the following questions.
Scenario:
There are 2 sites located 130 km away from one to the other and we want to provide a wan connectivity via ONS 15454.
Questions:
1. The ethernet / DWDM modules preferred
2. The typical wave length will be used -- 1550 or 1310?
3. What are the speeds supported on the modules?
4. What should be the recommended max losses / power budget for 130 km for Cisco ONS to work properly?
5. Any specific recommendations.
Thanks & Regards
Jay
supoonia
GE_XPE, 10GE_XPE,  OTU2_XP, ML cards,
CE-Series 10-Port Multirate Ethernet Card, 10DME, MXP, 10x10 there are lot of cards depends on your requirement, line rates coming from WAN device, types of module present on WAN side.
depends if you looking for a SDH/SONET solution, will say 1550, if DWDM than it will be composite siganal with MUX/DMUX.
10mbps, 100Mbps, 1000Mbps, 1Gig, 10Gig, 40gig and 100Gig depends on your requirement :-)
around 35dB to 39dB of span loss, looks you need amplification.
we need to discuss your requiremnets, there are lot of sloution available.
