Webcast-Catalyst9k
ONS-15454 V8.5 and SNMP V2c
Can someone tell me if the ONS-15454 support INFORM Traps?
I'm trying to get INFORM Traps working with my NMS, but I don't think it's working. Either I don't have it configured correctly or its supported on the ONS.
Many Thanks
Re: ONS-15454 V8.5 and SNMP V2c
ons supports notification traps, but u have to add the necessary mibs to your nms.
Hi. and thanks for the reply.
Correct me if I'm wrong, but Notification Traps are different than INFORM Traps. correct?
You are correct.  INFORM Requests are different from TRAPS.  Both are sent from the monitored device to the SNMP Manager.  Both advise the SNMP Manager of an event that has occurred.  The difference is the INFORM Request requires a response from the SNMP Manager while a TRAP does not.  The INFORM Request allows the monitored device to know that the SNMP Manager has received his message.
Now to the ONS... it supports TRAPS, but not INFORM Requests.
Mike Dooley
Cisco Heartland TAC
Thanks Mr. Dooley.
Can we find out if the ONS will support INFORMS in future sw releases??
Peter
Hi Peter!
I'll check and find out.
Mike
Peter,
It is not going to be in the latest release (9.2) and no word on putting it into future releases.
Sorry...
Mike
Thanks Mike. Appreciate the follow through.
Peter
699
