Optical 10GB modules
i want to connect 4506-e and 6506-e with 10gb technology .
Which modules and gbic are required?
Everyone's tags (3)
Re: Optical 10GB modules
You will need to know two things:
1. What is the distance between the switches?
2. What type of fiber optic cable do you have available to connect the equipment (multimode[OM-?] or singlemode)?
The table below (example) shows the supported Cable Distances for 10G, based on fiber Cable Type (this is for the SFP+ modules, but the other transceiver styles will typically have similar types).
Table 1. SFP+ Port Cabling  Specifications
Cisco SFP+
Wavelength (nm)
Cable Type
Core Size (microns)
Modal Bandwidth (MHz*km)***
Cable Distance*
Cisco SFP-10G-SR
850
MMF
62.5
62.5
50.0
50.0
50.0
160
200
400
500
2000
26m
33m
66m
82m
300m
Cisco SFP-10G-LRM
1310
MMF
SMF
62.5
50
50
G.652
500
400
500
220m
100m
220m
300m
Cisco FET-10G
850
MMF
50
50
500
2000
25m
100m
Cisco SFP-10G-LR
1310
SMF
G.652
10km
Cisco SFP-10G-ER
1550
SMF
G.652
40km**
Cisco SFP-H10GB-CU1M
Twinax cable, passive,  30AWG cable assembly
1m
Cisco SFP-H10GB-CU3M
3m
Cisco SFP-H10GB-CU5M
Twinax cable, passive,  24AWG cable assembly
5m
Cisco SFP-H10GB-ACU7M
Twinax cable, active, 30  AWG cable assembly
7m
Cisco SFP-H10GB-ACU10M
Twinax cable, active, 28  AWG cable assembly
10m
The following link will show you which transceiver style is compatible with your switch's hardware/software. Select the style that fits your hardware and also that matches your fiber type + link length you need.
10G transceiver compatibility matrix
<http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html>
10G transceiver data sheets
<http://www.cisco.com/en/US/products/ps6574/index.html>
Hope this helps!
Thanks Tom.
1) The distance is approximately  250 m
2) I don't have in this moment none of FC cable
I need to create new link between 4506-e and 6506-e.
I think that this product are compatible to work together:
1) On 4506-e i would install this module: WS-X4606-X2-E with this transceiver X2-10GB-SR
2) On 6506-e i would install this module: WS-X6708-10G-3Cwith this transceiver  X2-10GB-SR
Which cable FC i can buy?
Those transceivers look like the correct part numbers for your switch models.
You need to order a fiber cable with multiple OM 3 or OM4 rated multimode fibers (MMF); typically ordered from your favorite LAN products supplier.
Let us know if you need additional information.
Hall of Fame Super Gold
Off topic here ... I hope you are not expecting to push 10Gb (or more).  The 4500E can support 10Gb modules but can't really push 10Gb worth of traffic due to bandwidth limitation.
for support
2460
