Packet Over Sonet POS Config
jdeisenm
I'm trying to bring up a POS interface with the provider. My side is a 7200. The interface is currently up/down. When the provider put a loop facing me. I could ping my interface with no errors. Any thoughts? What questions can I ask the provider to verify the config on both their side and mine. Can the provider look at the circuit and see what parameters are being sent by each side?
didyap
Level 6
Level 6
For the troubleshoot the interface check whether the configuration for the both side is ok or what.
Here is the configuration and troubleshoot guide for the Packer Over Sonet
Follow the URL which will help you :
http://www.cisco.com/en/US/docs/routers/12000/gsr_linecards/pos_lc/installation/guide/16412pos.html#wp484667
