Community Member
Password Recovery ML-100 card
Is there anyway to do a password recovery for a ONS 15454 ML-100 card?
Re: Password Recovery ML-100 card
1. Log into CTC
2. Download IOS config from node to your PC
3. Open file on your PC and modify line with password/secret.
4. Save file and transfer it bask to TCC.
5. Right mouse click on ML card and select "reset card"
6. When ML is again up and running, you will be able to access card from CTC (again IOS
tab and click on button "Open IOS command line..."
Community Member
Thank you for your help, issue solved.
294
