Community Member
Problem with autonegotiation on 3750 Electrical port
Hi All,
I am facing a weird issue with auto-negotiation in CISCO 3750 switches. I have configured one switch port as duplex full and speed 1000 in both the switches. Now when I am connecting these two switch ports with RJ45 cable the link is showing down. If I change the duplex mode to auto in any one of the switches or both are kept in auto mode the link do shows up with the same cable. This issue is not faced if I use the optical ports instead of electrical port. Is this the correct behavior?
Any hints would be greatly appreciated!
Thanks in advance.
Re: Problem with autonegotiation on 3750 Electrical port
Try to perform switchport nonegotiate, udld port on ports.
Community Member
speed nonegotiate can be done in optical ports. In electrical ports no such option is available.
Hall of Fame Super Blue
Don't muddle the topic.
You're talking about hard-coding speed/duplex on a copper port.  You won't be able to hard-code speed/duplex on a fibre optic port.
Community Member
Agreed. So does this mean that with CISCO 3750 switch, full duplex on both side will not work?
This not only means auto-negotiation is disabled but MDI/MDI-X is also disabled.
Are you using cross-over cable or straight-through?
Community Member
This not only means auto-negotiation is disabled but MDI/MDI-X is also disabled- Is this normal? Can we enable this forcefully?
Are you using cross-over cable or straight-through?- Straight-through.
Highlighted
No.  If you disable speed and duplex auto-negotiation, MDI/MDI-X is disabled.  There's no way around it.
And this the the reason of your initial problem:  When you disable speed/duplex auto-negotiation you also disabled MDI/MDI-X.  When this happens the link between two switches are down because you're using the wrong cable.  The cable must be a cross-over cable.
752
