Product options for OC48 laser
I am looking for a 1310nm IR OC48 but I am having trouble figuring out what options Cisco provides that fit this qualification.  I apologize if this is the wrong forum for this type of question.  If so, and there is a right forum, if you would point me to it I would be grateful.
Re: Product options for OC48 laser
What hardware is this oc48 being installed in?
Sent via BlackBerry by AT&T
It's being put into a CISCO 15454
Previously an ONS-SE-Z1= and an ONS-SI-155-i1 have been used, but I'm not clear on the differences, other than the 155 being much less expensive.
The 155 is OC3
Thanks - I should have caught that.  So the ONS-SE-Z1= is ok?  Are there other options or is this the one.  Thank you again Tom.  I really appreciate the help.
I am stuck in snow traffic on crackberry. Look at the 15400 reference guide online.. I believe it has a x-ref table by intf card
Thanks.  Stay safe.  Looked at the guide and didn't see it - I'll keep looking around.
Does lhis doc help. Hard to view on phone.
http://m.mcisco.com/pocket.paper?url2=http%3a%2f%2fwww.cisco.com%2fen%2fUS%2fprod%2fcollateral%2foptical%2fps5724%2fps2006%2fbrochure_c02-452560.html
I'm still looking through it, but this looks like it has what I needed.  Thanks again!
Here is the document I was looking for.
http://www.cisco.com/en/US/docs/optical/spares/gbic/guides/ppms2.html#wp203291
You just need to know what card you are installing the transceiver in.
Good luck.
Thanks again Tom.  This got me what I needed.
643
