Community Member
Proper SFP module for use
I have a 15' optical handoff run from our ISP Flashwave to a 3845.  We need an SFP capable of handling 1310nm single-mode transmission, but the GLC-EX-SMD has far more power than we'd need.  I'm thinking a lower-powered SFP that still meets the transmission criteria would be less expensive and wouldn't require a 5dB attenuator.
I can't find another suitable option, can anyone suggest something different?  And if not, perhaps a link to optical attenuators that would work well with the GLC-EX-SMD?
Thanks in advance!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Proper SFP module for use
You're welcome and thanks for the rating.
Actually Cisco refers to it both ways (1300 and 1310). Please see Table 4 in this document (and contrast with Table 1).
The GLC-LH-SM/D is very commonly used in just this application - metro Ethernet and service provider type of handoffs.
You may also want to take a look a the excellent document on this forum that Tom has put together. I keep it bookmarked.
It would be best to match the reach type (1000Base-??) of the optical interface of the connecting Flashwave interface card. I would check with the ISP to see if they can install a data card that accepts a short haul (SX) transceiver.
A shorter reach 1310nm SFP compatible with the 3845 would be the 1000BASE-LX/LH, part number options include GLC-LH-SM & GLC-LH-SMD.
Adding to Tom's recommendations, I always prefer to use the SMD models when dealing with 3rd party handoffs since they allow me to check the send and receive optical power levels remotely. They cost a bit more but if they save a couple trips to the data center, they more than pay for the delta.
Community Member
Thank you Tom and Marvin.  I've actually looked into the GLC-LH-SM/D, but the specs state that they're 1300nm SFPs... my lack of optical experience puts me at a disadvantage in that I don't know if this will work with the ISP's 1310nm handoff.
Community Member
Wow that is excellent!  Thank you so much.
1389
