02-29-2012 06:51 PM
Hi there,
We have two ONS 15454 nodes that connected by two OC-48 from different vendor. I need some help to choose the protection type.
We only have one MRC-12 card per node. so 1+1 is not working for us because that is card protection. What else options do I have? Is there any protection for the port level on the same card?
WG
03-01-2012 06:47 AM
Do you have DCC interconnectivity between the 15454s over the OC-48 links from the two vendors?
The OC-48 links to the two vendors would each be unprotected. When you create a circuit from one 15454 to the other, the circuit would be set-up to use Path Protection (this is the default when creating a circuit). The Path Protection takes the input at 15454 #1 and bridges it, creating two circuits; one would traverse one OC-48 link and one would traverse the 2nd OC-48 link. At 15454 #2, the two circuits are received on the two OC-48 ports and come together in a switch (in the cross-connect card), which determines which path to use (which has a better signal quality) and connects it to the output port.
Using only one OC-N card in each node creates a single point of failure. So the system would only be able to correct for a link failure (single fiber break, one vendor's network down, etc.). Instead of using a 12-port MRC card, a 4-port MRC or a single OC-48 port card would be more appropriate.
Review the user documents for info on Path Protection or PPMN (Path Protected Mesh Networking).
03-01-2012 08:23 AM
Thanks for the quick answer. That is hardware we had now so I can only design based on this.
Let's assume the DCC is working now.
Would path protect also works for VCAT circuit? I cannot find the option when I create a VCAT circuit.
If the DCC is not working, i am thinking to create server trails between these two node. Then create a open-ended VCAT on both sides. Will that work and what is switching time if one fiber fails?
03-01-2012 10:19 AM
Each VCAT member would be a path protected circuit. If a fiber failed, <50msec is typically the switch time.
03-01-2012 10:34 AM
I cannot find any document details the path protection. Do you mind show me the link or some of the screenshot for creating a path protection circuit?
And what if DCC is not working? Can I still use path protection?
Thanks a lot.
WG
03-01-2012 11:32 AM
Data Cards
http://www.cisco.com/en/US/docs/optical/15000r9_0/ethernet/454/guide/45490ethernetguide.html
VCAT
Hope this helps.
03-06-2012 12:18 PM
I did a test in the lab using open vcat configuration. The circuit showed as protected.
But the switching time is longer than 50ms. Based on my ping test, when i unplug one OC-48, it lost about 2 -3 packets which means the failover is about 4-6 seconds.
03-06-2012 07:23 PM
You may be adding switching delays at a higher ISO layer delay. I believe you would have to test the switching time with a BER tester, such as in the below reference paper.
http://www.jdsu.com/productliterature/aps_wp_opt_tm_ae_0306.pdf
