Redesign Node using Metroplanner
dear all,
I already have 4 node ONS15454Sdh in ring configuration A-B-C-D-A, is there anybody know how to redesign the node if i wanna put new node 15454sdh between node B and node C.
i've tried this using metroplanner file, but i can't be done.
thanks!!
regards,
Rano
Re: Redesign Node using Metroplanner
Get the ONS Procedure Guide appropriate for the software version you're running.
http://cisco.com/en/US/partner/products/hw/optical/ps2006/prod_installation_guides_list.html
It has a chapter called "Add and Remove Nodes", usually chapter 14. It provides detailed instructions.
thanks for reply "Greg",
as u know i have 4 node ONS15454sdh release 7.2.2 and i've read the installation & procedure guide, it doesn't mentioned how to insert new node without doing it first in metroplanner.
and how could i do it, if the cisco metroplanner analyze showing error command.
thanks.
Rano
141
