SC/PC to MTRJ
I have problem with connect PA-POS-OC3SMI (with SC/PC connector) to OSM-4OC3-POS-SI (with MTRJ connector). I have SC/PC-MTRJ patchord and I tried several different configurations and nothing. Maybe someone have the same problem?
Green
Re: SC/PC to MTRJ
I believe you are having a "power problem" ....(too much optical power)
You don't mention any distances between the devices you are connecting (you did say "patch cord", so I'm guessing it's close), but the PA-POS-OC3SMI is an intermediate reach device ("medium" power); if the devices are closer than a couple fiber-miles away, then you will probably need some optical attenuation to reduce the power level to the receiver (both sides).
Good Luck
Scott
Re: SC/PC to MTRJ
The documentation for both of these modules show output powers up to a max of -8dBm, with Rx overload of -8dBm and Rx sensitivity down to -28dBm.
Provided you are using a SM patch cord, you should be OK (but as Scott mentions, a little attenuation wouldn't hurt). I would recommend you check the Rx power level at each end with a power meter. This should confirm if the patch lead is OK, or if the power levels are out of range.
Rob.
Re: SC/PC to MTRJ
Thanks for help.
This time it was card problem, it was broken.
197
