SFP-10G question
Does it work if I connect the SFP-10G-SR to SFP-10G-LRM using 10G multimode fiber?
1 ACCEPTED SOLUTION
I dont think so, they should be the same SFP model on both ends.
SFP-10G-SR=
10GBASE-SR SFP+ transceiver module for MMF, 850-nm wavelength, LC duplex connector
SFP-10G-LRM=
10GBASE-LRM SFP+ transceiver module for MMF and SMF, 1310-nm wavelength, LC duplex connector
SFP-10G-SR=
SFP-10G-LRM=
Hall of Fame Super Gold
Will not work.  It's either
Will not work.  It's either SR to SR or LRM to LRM.
These two modules use
These two modules use different fiber cables as the transmission media, it will not work out.
It will definitely work if
It will definitely work if you use a mode-conditioning patch cord.
See here: http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/product_bulletin_c25-530836.html
It could work if you use all normal MM cabling. It's hit-or-miss.
102
