SFP GLC-EX-SMD dont work in C3KX-NM-1G Module on switch WS-3560X-48T
We insert a SFP GLC-EX-SMD in a Module C3KX-NM-1G, in switch ws-3560X-48T, but appear a message " dont supported" and the port remains in error-disable. we probe in the four port of module C3KX-NM-1G.
In paper from webpage of Cisco, say that is supported this sfp GLC-EX-SMD, but we have to use other IOS 12.2.58.SE, but this ios not exist for these switch.
The switch have ios 12.2.55.SE5. we need this SFP for a distance over ten kilometer.
Link when appear data from switch 3560X, sfp and nm.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
My question is. is supported or need extra configuration for that SFP GLC-EX-SMD work in a Module C3KX-NM-1G, in switch ws-3560X-48T?
Hall of Fame Super Gold
You need to upgrade the IOS
You need to upgrade the IOS of your 3750X stack to 15.0(2)SE4.
Hi leoit is a switch 3560x
Hi leo
it is a switch 3560x 48T-E not a 3750X.
Same thing. Upgrade the
Same thing. Upgrade the switch to 15.0(2)SE4. According to the Release Notes, this SFP is supported on 12.2(58)SE2 but I am no idi0t and I won't recommend anyone using the entire 12.2(58)SE because there are more bugs in this train than the Amazon.
HiIt is a switch WS-3560X-48T
It is a switch WS-3560X-48T-E. the IOS 12.2.58.SE is not available for this switch.
254
