sfp module problem in 3560
Hi all,
I have two same switches: S1 - WS-C3560X-24P (ver. IOS 12.2 SE2).
I put them two identical SFP modules CISCO GLC-SX-MM SFBR-5766PZ. (inter gi1/1 or gi1/2)
I reset the factory settings.
I tried:
no shutdown
service unsupported-transceiver
but still (not connected or down)
When connecting media converters (DIGITUS) -  all works
Please help with the interface configuration step by step, because I lose my job.
Switch#sh logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 14 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 14 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 16 message lines logged
Log Buffer (4096 bytes):
*Mar 1 00:00:04.613: Read env variable - LICENSE_BOOT_LEVEL =
*Mar 1 00:00:07.054: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560x Next reboot level = ipbase and License = ipbase
*Mar 1 00:00:52.957: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 1 00:00:54.702: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 1 00:00:58.695: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
*Mar 1 00:01:16.999: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:57 by prod_rel_team
*Mar 1 00:01:18.685: MKA-LLI: Failover Event
*Mar 1 00:01:19.222: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
*Mar 1 00:01:20.857: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar 1 00:01:21.444: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.
*Mar 1 00:01:25.412: %PLATFORM-6-FRULINK_INSERTED: FRULink 10G ST module inserted.
*Mar 1 00:05:12.433: %SYS-5-CONFIG_I: Configured from console by console
*Mar 1 00:07:54.686: %SYS-5-CONFIG_I: Configured from console by console
*Mar 1 00:08:47.341: %SYS-5-CONFIG_I: Configured from console by console
Switch#
Switch#sh run
Building configuration...
Current configuration : 1504 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
Switch#sh interfaces gig1/1
GigabitEthernet1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ccef.48a5.8419 (bia ccef.48a5.8419)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Switch#
Switch#sh interface gig1/1 summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
GigabitEthernet1/1 0 0 0 0 0 0 0 0 0
Switch#
Switch#sh interface gig1/1 counters errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Gi1/1 0 0 0 0 0 0
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants
Gi1/1 0 0 0 0 0 0 0
Switch#
HELP?
Hi Tomasz,
Follow the below steps:-
1) ensure that the module is detected in switch by show inventory
2) Ensure fiber link which is Mumltimode or single mode
3) Check red led in module as well as in fiber patch cord. both should be cross.
Hi bharat chaudhari,
I follow Y steps:
1)
Switch#sh inventory
NAME: "1", DESCR: "WS-C3560X-24P"
PID: WS-C3560X-24P-S   , VID: V02  , SN: FDO1536V09D
NAME: "Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-715WAC   , VID: V01  , SN: LIT152903B9
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
PID: C3KX-NM-10G       , VID: V01  , SN: FDO15331HK8
NAME: "GigabitEthernet1/4", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN: AGM12301ECP
and
Switch#sh inter gi1/4 capabilities
GigabitEthernet1/4
  Model:                 WS-C3560X-24P
  Type:                  1000BaseSX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
I have multimode fiber link.
On C3KX-NM-10G Network module leds always off (no reactions on plug in SFP module).
I check fiber patch cord on croos and no cross - no diffrent - no alive.
At the end sh runn
Switch#sh runn
Current configuration : 1652 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
no errdisable detect cause gbic-invalid
no ip address
speed nonegotiate
speed nonegotiate
speed nonegotiate
speed nonegotiate
interface Vlan1
no ip address
ip classless
ip http server
line con 0
line vty 5 15
end
help?
Hall of Fame Super Gold
Why do you have this command for?
This is useless information.  What is EXACTLY your IOS version?
Post the complete output to the command "sh idp interface G1/4".
Hi Leo Laohoo,
This command someone tell mi to check,
Two switches connected the short optical fiber. One port is up. The second is still down. I have two identical configurations (switch) except vlan1 192.168.0.1 and 192.168.0.2
shutdown / no shutdown does not help.
I have sh ver and idp.
Switch#sh ver
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
Switch uptime is 1 hour, 0 minutes
System image file is "flash:/c3560e-universalk9-mz.122-55.SE3/c3560e-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24P (PowerPC405) processor (revision B0) with 262144K bytes of memory.
Processor board ID FDO1536V09D
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : CC:EF:48:A5:84:00
Motherboard assembly number     : 73-12555-05
Motherboard serial number       : FDO15361GBA
Model revision number           : B0
Motherboard revision number     : D0
Model number                    : WS-C3560X-24P-S
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO15360C3Q
System serial number            : FDO1536V09D
Top Assembly Part Number        : 800-31329-02
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJS00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24P      12.2(55)SE3           C3560E-UNIVERSALK9-M
Configuration register is 0xF
Switch#sh idp inter gig1/1
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x01 0x00 0x00 0x00 0x00
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO-AVAGO
Vendor Part Number    :   SFBR-5766PZ
Vendor Revision       :   0x20 0x20 0x20 0x20
Vendor Serial Number  :   AGM12301ECP
Other Information
Port asic num         : 00
Port asic port num    : 06
SFP presence index    : 00
SFP iter cnt          : 27272
SFP failed oper flag  : 0x00000000
IIC error cnt         : 0
IIC error dsb cnt     : 0
IIC max sts cnt       : 6
Chk for link status   : 01
Link status           : 01
Autoneg enable        : 00
Flow control Pause    : 00
Flow control asymPause: 00
Duplex mode           : 00
PcsInfo               : 0x05331AA0
MacInfo               : 0x05331A88 0x05331A80
AutoNeg               : 0x05331A80 0x05331A88
Sfp selection asic reg map
stbi                 : 0x00
sfpControl           : 0x4E
Regs Loc             : 0xF0000000
miscStatus
   rps300Stat1      1
   rps300Stat2      1
   rps300Present    1
   modeSwitchActive 0
stackPhyControl
   sPhyLoopback     0
   sPhyALock1       1
   sPhyALock0       1
   sPhyBLock1       0
   sPhyBLock0       1
stackCable
   cableIdA_1       0
   cableIdA_0       1
   eqSelectA_1       0
   eqSelectA_0       0
   cableIdB_1       0
   cableIdB_0       1
   eqSelectB_1       0
   eqSelectB_0       0
SFF-8472 MSA EEPROM Data
000 :  03 04 07 00 00 00 01 00 00 00
010 :  00 01 0D 00 00 00 37 1B 00 00
020 :  43 49 53 43 4F 2D 41 56 41 47
030 :  4F 20 20 20 20 20 00 00 17 6A
040 :  53 46 42 52 2D 35 37 36 36 50
050 :  5A 20 20 20 20 20 20 20 20 20
060 :  03 52 00 ED 00 1A 00 00 41 47
070 :  4D 31 32 33 30 31 45 43 50 20
080 :  20 20 20 20 30 38 30 37 32 35
090 :  20 20 00 00 00 D4 00 00 06 7A
100 :  4B 2E 0B FD CD 98 5B DC 1F 04
110 :  8A 29 51 74 86 00 00 00 00 00
120 :  00 00 00 00 F2 43 EA C0
YETI INTERNAL REGS
Location=0xD8000500     :  Value=0x00
Location=0xD8000501     :  Value=0x00
Location=0xD8000502     :  Value=0x00
Location=0xD8000503     :  Value=0x00
Location=0xD8000504     :  Value=0x00
Location=0xD8000505     :  Value=0x00
Location=0xD8000506     :  Value=0x00
Location=0xD8000507     :  Value=0x02
Location=0xD8000508     :  Value=0x00
Location=0xD8000509     :  Value=0x40
Location=0xD800050A     :  Value=0x00
Location=0xD800050B     :  Value=0x00
Location=0xD800050C     :  Value=0x05
Location=0xD800050D     :  Value=0x00
Location=0xD800050E     :  Value=0x01
Location=0xD800050F     :  Value=0x00
Location=0xD8000510     :  Value=0x0F
yetiIICinited           :  Value=0x00000001
yetiIICLockPassCnt      :  Value=0
yetiIICLockFailCnt      :  Value=0
yetiIICLockApp          :  Value=35
Switch#sh runn
Current configuration : 3300 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki trustpoint TP-self-signed-1218806784
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1218806784
revocation-check none
rsakeypair TP-self-signed-1218806784
crypto pki certificate chain TP-self-signed-1218806784
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323138 38303637 3834301E 170D3933 30333031 30303031
  32325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32313838
  30363738 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C88C EF241877 24B0441E BDDC8A90 A6505A21 35F3C17F A62FEB85 04940363
  C3201331 DDA767FF F78AE7BC 7EA326B3 FDC0385E E871E1E8 29D0C912 5EFEBB1C
  4EB7AA24 611D8C75 9AF5F288 1A3C8F90 B7D2470B 71B47E9C 9849A1E8 636C9B32
  DEDE8112 7D1391EC B12D6ED1 F24A4C61 69D8DF1F FCBAA3EF 6D6DCDEB A767DAB1
  5F150203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07537769 7463682E 301F0603 551D2304 18301680 1471FECC
  C14AB1D2 6B947571 8A54621A D16FBD39 8F301D06 03551D0E 04160414 71FECCC1
  4AB1D26B 9475718A 54621AD1 6FBD398F 300D0609 2A864886 F70D0101 04050003
  81810036 07E4C958 BC358C2A 934C8EC8 83EEF5AC 3CFE7A96 E7FC54DE A9216FE9
  11986898 3D3A9663 E516A971 68FA225C C387C12D 77606551 50FBAD91 31A5C3FE
  70EACE07 021EBEAD 4072AA28 C80CD3A3 C9A73C52 4B0F121D 42A82FB8 02B3CDB1
  B91C0CDC F2DF8079 37CE197B E4335AF3 3EB1D5CF D37D12F6 7DB18CE2 C2CE5B9F 215F6C
  quit
no ip address
speed nonegotiate
speed nonegotiate
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip classless
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
11351
