You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Supervisor Engine 6-E (WS-X45-Sup6-E) configuration for 10G and 1G connectivity
Hi Community,
I need to confirm something.
With the WS-X45-Sup6-E supervisor engine, is it possible to use one of the uplink ports with the X2 optics for 10G speeds and the other port with a Cisco Twin Gigabit Converter Module so as to have 2 1Gb ports?
Or does it only work with 2 10Gb or 4 1Gb only?
Peter
  • Optical Networking
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Sorry but you can't mix and
Sorry but you can't mix and match on the Sup 6. There's a single stub ASIC inside the card which causes this limitation.
The configuration guide explains it here.
1 REPLY
804
