Community Member
TCC2P?s CLI on ONS 15454
Is there any possibility to set up the node ip address, mask and default gateway by the CLI command on the TCC2P card.
1 ACCEPTED SOLUTION
Re: TCC2P?s CLI on ONS 15454
Yes, via the TL1 command line.
See:
http://www.cisco.com/en/US/products/hw/optical/ps2006/prod_command_reference_list.html#anchor2
1. You can reach the TL1 CLI by Telnetting to port 3083.
EX: telnet 192.1.0.2 3083
You should get the '>' prompt.
You could also connect to the Craft interface on the TCC2P card.
2. Start the TL1 session:
EX: ACT-USER::CISCO15:123::otbu+1;
Where CISCO15 is the User ID and otbu+1 is the password.
3. Use the ED-NE-GEN command
SYNTAX:
ED-NE-GEN:[]:::::[NAME=],[IPADDR=],
[IPMASK=],[DEFRTR=],[IIOPPORT=],
[NTP=],[ISPROXYSERVER=],[ISFIREWALL=],
[SUPPRESSIP=],[MODE=];
Edits the general node attributes of an NE.
EX: ED-NE-GEN:::123:::IPADDR=10.89.251.201,IPMASK=255.255.255.192,DEFRTR=10.89.251.193;
1 REPLY
See:
SYNTAX:
473
